DIALux evo 13
Innovations and improvements
We are happy to present the new version of DIALux evo. Our team has worked hard to make major improvements that will enhance your lighting design experience, making it more efficient and saving you valuable time.
DIALux evo 13 Patch 1
Version: 5.13.0.9498 | Released: 09/10/2024
DIALux evo
Fixed errors
- Projects with embedded DWG can now be saved again without any problems.
- The programme no longer crashes during the quick calculation of emergency lighting.
DIALux evo 13: New functions and improvements
Version: 5.13.0.9477 | Released: 26/09/2024
DIALux evo
New obtrusive light scene
You now have a dedicated light scene for obtrusive light calculations, set with a maintenance factor of 1 by default. Add all exterior luminaires with just one click.
DIALux evo
Obtrusive light tool
A new tool allows you to place and configure obtrusive light objects easily.
DIALux evo
Comprehensive obtrusive light calculations
Calculate key values like I, ks, Ruf, Rul, RULO, and RDLO with precision.
DIALux evo
Advanced RG calculation options
Choose between specifying a fixed value or placing a special veiling luminance surface for RG calculations.
DIALux evo
Obtrusive light checklist
Stay on track with a checklist covering all necessary settings for obtrusive light calculations.
DIALux evo
Enhanced result monitor
View scene-wide results, including luminous flux ratios, directly in the result monitor.
DIALux evo
Expanded calculation object list
Obtrusive light parameters are now integrated into the calculation object list.
DIALux evo
New documentation for obtrusive light
Outputs now feature luminous flux ratios, giving you a clear view of obtrusive light impacts.
DIALux evo
Revised calculation settings
Calculation settings now include comprehensive options for obtrusive light.
DIALux evo
Enhanced display for ks Value
Show the ks value with isolines, false colors, or value charts to visualize obtrusive light effects more effectively.
DIALux evo: Improvements to existing functions
DIALux evo
Signal color results
Results monitors now use distinct signal colors for normal, emergency, and obtrusive light scenes – making scene identification immediate.
DIALux evo
Color-Coded Light Scenes
Light scenes are now color-coded to help you distinguish between different types at a glance.
DIALux evo
Simplified RG display
We’ve made the RG result display clearer and easier to interpret.
DIALux evo
Revised isoline and color settings
Isolines, false colors, and value graphics settings are now independent of unit settings.
DIALux evo
Improved calculation point visibility
Calculation points are now easier to find in CAD, saving you time.
DIALux evo
Light source preview
See a preview of the LDC for selected light sources, enhancing your design process.
DIALux evo
Faster Start
We’ve accelerated the program start, especially when loading data from your last projects.
DIALux evo
Standardized Object Catalogue Layout
We’ve unified the layout across different object catalogs for a smoother experience.
DIALux evo
- Fixes include issues with daylight system settings, 2D helping line tools, clipboard import errors, and several display and calculation inconsistencies.
DIALux Pro: New functions and improvements
DIALux Pro
IFC Import Extension
- Enhanced IFC Model import: Choose between a new and legacy import method. The new method cuts down solid modeler operations, boosts stability, and shortens import times, especially with complex models. The new method excels with intricate models loaded with floors, rooms, and architectural details. Be aware of minor side effects like shadow edges with the new method; switch to legacy if needed.
- Legacy Method: Reduces visualization issues but might slow down and destabilize the import of complex models.
- Expanded Import Flexibility: Import IFC models even if they don’t include a building – pure exterior areas are now supported.
DIALux Pro
Workflow: Spaces
- Direct Space Import: DIALux now imports spaces exactly as defined in the IFC model – names, descriptions etc.
- No automatic Space creation: Spaces won’t be auto-created if missing; however, you can still add them manually when needed.
- More flexible Spaces: Spaces can be geometrically adjusted within DIALux, allowing for adjacent, rather than nested, layouts.
- Updated IFC Export: All spaces and their luminaires are now included in the export, making it easy to track luminaire placement in BIM workflows.
DIALux Pro
Live data exchange with GRAPHISOFT DDScad
- Live Data Integration: Connect DIALux and DDScad on the same workstation for real-time IFC data exchange.
- Seamless Planning and Export: Start DIALux directly from DDScad, plan lighting, and sync the models effortlessly.
- Open BIM and IFC Support: Built on open BIM standards, this feature ensures smooth interoperability with other platforms.
DIALux Pro
Metaroom 3D Model Support
- Import scanned 3D models: Bring in complex, scanned models from Metaroom Studio directly into DIALux evo.
- Lighting design in scanned spaces: Plan lighting in the scanned environments and export your work seamlessly for further BIM processes.
